  Le 1/16/2010 à 10:11 PM, moxfulder69 a dit :
Bonjour, Apr
  Le 1/17/2010 à 2:16 PM, phi a dit :
bonjour
vi fred un truc comme ca
Set WSHShell = CreateObject("WScript.Shell")
WSHShell.run "telnet.exe 192.168.1.2"
wscript.sleep 1000
WSHShell.sendkeys "root~"
wscript.sleep 1000
WSHShell.sendkeys "motdepasse~"
wscript.sleep 1000
WSHShell.sendkeys "poweroff~"
j'avais mis de cot
  Le 1/18/2010 à 12:08 AM, phi a dit :
bonsoir,
bah si tu me fais la meme en powershell ca me va :-)
ssh suffit. Pour windows, utiliser plink (version ligne de commande de putty) :
Z:\sysosd>plink
PuTTY Link: command-line connection utility
Release 0.60
Usage: plink [options] [user@]host [command]
       ("host" can also be a PuTTY saved session name)
Options:
  -V        print version information and exit
  -pgpfp    print PGP key fingerprints and exit
  -v        show verbose messages
  -load sessname  Load settings from saved session
  -ssh -telnet -rlogin -raw
            force use of a particular protocol
  -P port   connect to specified port
  -l user   connect with specified username
  -batch    disable all interactive prompts
The following options only apply to SSH connections:
  -pw passw login with specified password
  -D [listen-IP:]listen-port
            Dynamic SOCKS-based port forwarding
  -L [listen-IP:]listen-port:host:port
            Forward local port to remote address
  -R [listen-IP:]listen-port:host:port
            Forward remote port to local address
  -X -x     enable / disable X11 forwarding
  -A -a     enable / disable agent forwarding
  -t -T     enable / disable pty allocation
  -1 -2     force use of particular protocol version
  -4 -6     force use of IPv4 or IPv6
  -C        enable compression
  -i key    private key file for authentication
  -noagent  disable use of Pageant
  -agent    enable use of Pageant
  -m file   read remote command(s) from file
  -s        remote command is an SSH subsystem (SSH-2 only)
  -N        don't start a shell/command (SSH-2 only)
  -nc host:port
            open tunnel in place of session (SSH-2 only)
donc la commande
plink root@syno halt
associ
salut,
question en multi-user si quelqu'un d'autre est connecté il vaut pas mieux un shutdown qu'un halt ?
du style envoyer une alerte au gus connecté via un wall et lui laissé un répits de 10 minutes pour enregistrer son truc en cours puis lancer le halt ?
shutdown -m +10
tu es bien plus calé que moi et je me pose juste la question si il y a une contrainte que je ne saisirais pas au cas ou sur la séquence.
ce qui équivaudrais à un bon vieux net send tempo puis stop via bat, ou en bien plus évolué via gpo
merci
  Le 1/18/2010 à 9:57 PM, MS_Totor a dit :
salut,
Merci Phi,
Je viens de faire un test avec la solution Visual Basic, en copiant le code dans un fichier => extension '.vbs'
Parfait, sur XP en standard.
Fred.
  • 1 an après...
J'ai un message d'erreur lors de la commande halt
C:\>plink root@SYNO halt
root@SYNO's password:
FATAL ERROR: Server unexpectedly closed network connection
puis ma nas de repond pas, plus de reseau et ne s'arret pas non plus
J'ai une 710+ avec DSM 3.0
  • 10 mois après...
C'est peut-être un peu tard, mais j'ai écrit un solution qui va super bien, et pour une fois que je peux répondre au lieu de chercher des infos !
Il faut définit une tâche dans le crontab de root :
*/2 * * * * /usr/local/bin/ISPOFF 2>&1 (ça lance le script ISPOFF toutes les 2 minutes, mais ça ne prend pas beaucoup de ressources)
et ensuite le script lui.même :
#ISPOFF, arrête la machine si fichier poffile existe
FILE=/volume1/DATA/poffile
if [ -r $FILE ] ; then
echo "Arret machine"
rm $FILE
/sbin/poweroff
fi
Pour arrêter la machine, il sufit de transférer un fichier qui s'appelle poffile dans le répertoire /volume1/DATA p. ex. .J'utilise un programme qui s'apelle Backup magic, et à la fin,
je lance le batch C:\usr\local\bin\PoffSyno.cmd qui contient :
echo "STOP" >//Synology/DATA/poffile
shutdown.exe -s
Et, cerise sur le gâteau, il arrête le PC également. Comme ç je peux aller regarder mon téléjournal après avoir lancé une sauvegarde automatique qui éteint tout à la fin !
J'espère que ce n'est par trop compliqué à suivre ! mais ça fonctionne depuis 2 ans sans loupé !
  • 8 mois après...
Onduleur : APC Back-UPS ES 700G
3.14.10 (13 September 2011) redhat
Script d'extinction automatique depuis serveur Linux :
- Conditions :
1) Avoir un autologin SSH depuis votre Linux Server vers votre NAS Synology.
Si vous en avez besoin, je peux poster les commandes qui permettent de le faire.
2) Avoir le câble USB de votre UPS branché sur le serveur Linux et non sur votre NAS.
- Mise en place du script :
1) Vérification du statut de l'UPS
2) Login SSH dans le NAS + arrêt MySQL et Apache
3) Extinction du NAS
4) Arrêt Apache + MySQL du serveur Linux
5) Extinction du serveur
Ça vous dit ?
donne toujours, on verra ce qu'on peut en faire ;)
(en fait, moi qui suis paresseux, je prends volontiers ce que les autres font, quitte à modifier selon mes besoins).
Ce qui m'intéresse, c'est le "1) Vérification du statut de l'UPS", sachant que ce n'est pas sur un syno mais sur un zentyal (base ubutu server)
  • 1 an après...
Je serai aussi intéressé pour mettre en place ce genre de script mais mon besoin est inverse, je m'explique;
Le câble UPS est connecté sur le NAS et c'est lui qui doit donner l'ordre à mes serveurs (Windows et Linux) de s’arrêter.
Mais peut etre que ton script est adaptable ?
En tout cas je suis preneur
je vais répondre pour la partie Windows, je laisserai d'autre contributeurs se charger de la partie unix (tip: ssh -i <chemin clé privée> <user>@<host> shutdown, mais faut un peu enrober pour faire ça en toute sécurité)
Donc voila:
  • Coté Windows
    • sur le serveur cible activer le service RemoteRegistry
      Les commandes (à exécuter dans une boite de commande en mode administrateur) sont:
      sc config RemoteRegistry start= auto
      sc start RemoteRegistry
    • ensuite dans la branche de la base de registre:
      "HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionPoliciesSystem"
      créer l'entrée "LocalAccountTokenFilterPolicy" (de type 32-bit DWORD) et lui donner la valeur "1"
    • bien qu'on puisse utiser le compte windows "Administrateur" pour cela je préconise de créer un compte dédié (on l'apellera "shutdown"). Ce compte doit être membre d'un groupe disposant du privilege "Forcer l’arrêt à partir d’un système distant" ce qui par défaut n'est le cas que du groupe des administrateurs mais ça peut se modifier (sur les versions pro) si on le souhaite avec la console "Stratégie de sécurité locale"
  • Coté NAS:
    Das un script, on va alors pouvoir arréter le serveur Windows à partir du NAS avec la commande:
    net rpc shutdown -I <ip du PC windows> -U shutdown%<mot_de_passe>
    La commande "rpc shutdown" accepte les switches suivants (extrait de la doc)
    RPC SHUTDOWN [-t timeout] [-r] [-f] [-C message]
    • "-r": Reboot after shutdown.
    • "-f": Force shutting down all applications.
    • "-t <timeout>": Timeout before system will be shut down. An interactive user of the system can use this time to cancel the shutdown.
    • "-C <message>": Display the specified message on the screen to announce the shutdown
**EDIT**
Ah, j'oubliais: la commande "net" se trouve dans "/usr/syno/bin", s'assurer que ce répertoire est bien dans le PATH.
Modifié par CoolRaoul
