Besoin D' Aide Sur Antivirus Essential
Bonjour la Communautée :D
Aujourd'hui pour la première fois je sollicite vos Lumières car la mienne est éteinte.
Matos => DS410J sous DSM 5.0-4528 Update 2
Voici 3 semaines que l'antivirus ne scan plus aucun fichier
1 °La mise a jour se fait correctement
Tue Nov 25 17:50:42 2014 -> ClamAV update process started at Tue Nov 25 17:50:42 2014
Tue Nov 25 17:50:42 2014 -> WARNING: Your ClamAV installation is OUTDATED!
Tue Nov 25 17:50:42 2014 -> WARNING: Local version: 0.98.4 Recommended version: 0.98.5
Tue Nov 25 17:50:42 2014 -> DON'T PANIC! Read http://www.clamav.net/support/faq
Tue Nov 25 17:50:42 2014 -> main.cld is up to date (version: 55, sigs: 2424225, f-level: 60, builder: neo)
Tue Nov 25 17:50:52 2014 -> Downloading daily-19656.cdiff [100%]
Tue Nov 25 17:50:52 2014 -> Downloading daily-19657.cdiff [100%]
Tue Nov 25 17:50:52 2014 -> Downloading daily-19658.cdiff [100%]
Tue Nov 25 17:50:52 2014 -> Downloading daily-19659.cdiff [100%]
Tue Nov 25 17:50:52 2014 -> Downloading daily-19660.cdiff [100%]
Tue Nov 25 17:50:52 2014 -> Downloading daily-19661.cdiff [100%]
Tue Nov 25 17:50:52 2014 -> Downloading daily-19662.cdiff [100%]
Tue Nov 25 17:51:00 2014 -> Downloading daily-19663.cdiff [100%]
Tue Nov 25 17:51:01 2014 -> Downloading daily-19664.cdiff [100%]
Tue Nov 25 17:51:01 2014 -> Downloading daily-19665.cdiff [100%]
Tue Nov 25 17:51:01 2014 -> Downloading daily-19666.cdiff [100%]
Tue Nov 25 17:51:01 2014 -> Downloading daily-19667.cdiff [100%]
Tue Nov 25 17:51:01 2014 -> Downloading daily-19668.cdiff [100%]
Tue Nov 25 17:51:02 2014 -> Downloading daily-19669.cdiff [100%]
Tue Nov 25 17:51:02 2014 -> Downloading daily-19670.cdiff [100%]
Tue Nov 25 17:51:02 2014 -> Downloading daily-19671.cdiff [100%]
Tue Nov 25 17:51:02 2014 -> Downloading daily-19672.cdiff [100%]
Tue Nov 25 17:51:02 2014 -> Downloading daily-19673.cdiff [100%]
Tue Nov 25 17:51:03 2014 -> Downloading daily-19674.cdiff [100%]
Tue Nov 25 17:51:03 2014 -> Downloading daily-19675.cdiff [100%]
Tue Nov 25 17:51:11 2014 -> Downloading daily-19676.cdiff [100%]
Tue Nov 25 17:51:11 2014 -> Downloading daily-19677.cdiff [100%]
Tue Nov 25 17:51:11 2014 -> Downloading daily-19678.cdiff [100%]
Tue Nov 25 17:51:11 2014 -> Downloading daily-19679.cdiff [100%]
Tue Nov 25 17:51:16 2014 -> daily.cld updated (version: 19679, sigs: 1274247, f-level: 63, builder: neo)
Tue Nov 25 17:51:16 2014 -> bytecode.cld is up to date (version: 242, sigs: 46, f-level: 63, builder: dgoddard)
Tue Nov 25 17:52:00 2014 -> Database updated (3698518 signatures) from db.local.clamav.net (IP: 46.29.125.16)
Tue Nov 25 21:54:06 2014 -> --------------------------------------
Après quelques investigations je me suis rendu compte que l'initialisation du moteur de l'antivirus patine
dans la choucoutre.
Je l'ai laissé tourné plus de 24h en vain Rrrrrrrrrrr
Bloque toujours à l'étape 3 "init engine"
2° Lancement du Scan
NAS> /var/packages/AntiVirus/target/bin/synoavscan -f /homes/bruno
Start scanning with a given file list
Set StrucAVCmd and Start AVScan
poped from the queue
Update if needed...
Filling the Scan command structure for task 3...
parse config...
init engine...
TOP
PID PPID USER STAT VSZ %MEM %CPU COMMAND
23252 13691 root R 16552 13.9 92.1 /usr/syno/synoman/webman/3rdparty/AntiVirus/antivirus.cgi
23251 13285 root R 4224 3.5 7.6 top
13607 13595 http S 290m250.4 0.0 /usr/bin/httpd -DHAVE_PHP
13586 13561 http S 187m161.3 0.0 php-fpm: pool www
13587 13561 http S 186m161.0 0.0 php-fpm: pool www
13561 1 root S 186m161.0 0.0 php-fpm: master process (/etc/php/php-fpm.conf)
13700 7432 root S < 138m119.7 0.0 /usr/bin/httpd -DSSL -DSPDY -f /etc/httpd/conf/httpd.conf-sys
4° Contrôle de l'espace disque
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/md0 2451064 610748 1737916 26% /
/tmp 59248 792 58456 1% /tmp
/dev/vg1/volume_1 1913558460 1148864740 764591320 60% /volume1
/dev/vg2/volume_2 476058688 204012 475752276 0% /volume2
5° Action réalisée
Desinstallation du packet - reboot du Nas - Reinstallation de celui ci
Le problème Persiste!!!!!!!!!!!!! :angry:
J'attends donc avec impatience ;) vos suggestions qui pourront me faire avancer sur mon problème
Par avance merci pour vos retours
