Je viens de passer mon 107+ en 2.2. Je redemarre mon syno et la plus de sql.
Lorsque je veux redemarrer le process jai ce message d'erreur :
ERROR! MySQL manager or server PID file could not be found!
Vous pouvez m'aider ?
salut
regarde dans l administration de ton syno section "services reseau" services Web si la case activer MySQL est cocher
Romain
Oui bien sur la case est cochée.
Voila ce que j'ai lorsque j'essaye de demarrer le process mysql :
DiskStation> ./S21mysql.sh start
Need to upgrade MySQL database. Starting...
090912 14:52:30 mysqld_safe Logging to '/var/services/mysql/DiskStation.err'.
090912 14:52:30 mysqld_safe Starting mysqld daemon with databases from /var/services/mysql
090912 14:52:33 mysqld_safe mysqld from pid file /tmp/mysqld.pid ended
Looking for 'mysql' as: /usr/syno/mysql/bin/mysql
Looking for 'mysqlcheck' as: /usr/syno/mysql/bin/mysqlcheck
Running 'mysqlcheck'...
/usr/syno/mysql/bin/mysqlcheck: Got error: 2002: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) when trying to connect
FATAL ERROR: Upgrade failed
Stopping MySQL...
090912 14:52:54 mysqld_safe Logging to '/var/services/mysql/DiskStation.err'.
090912 14:52:55 mysqld_safe Starting mysqld daemon with databases from /var/services/mysql
090912 14:52:58 mysqld_safe mysqld from pid file /tmp/mysqld.pid ended
Stopping MySQL...
Starting MySQL...
Starting MySQL.... ERROR! Manager of pid-file quit without updating file.
MYSQL data dir = /volume1/@database/mysql...
DiskStation>
Peux tu nous donner ce que contiens le fichier '/var/services/mysql/DiskStation.err'
Pour info moi j'avais cela :
InnoDB: If you want bigger or smaller log files, shut down the
InnoDB: database and make sure there were no errors in shutdown.
InnoDB: Then delete the existing log files. Edit the .cnf file
InnoDB: and start the database again.
090821 19:36:33 [ERROR] Plugin 'InnoDB' init function returned error.
090821 19:36:33 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
090821 19:36:33 [ERROR] /usr/syno/mysql/libexec/mysqld: unknown variable 'innodb_log_arch_dir=/var/services/mysql/'090821 19:36:33 [ERROR] Aborting
090821 19:36:33 [Note] /usr/syno/mysql/libexec/mysqld: Shutdown complete
090821 19:36:34 mysqld_safe mysqld from pid file /var/services/mysql/DiskStation.pid ended
090821 21:08:56 mysqld_safe Starting mysqld daemon with databases from /var/services/mysql
090821 21:08:56 [Warning] option 'thread_stack': unsigned value 65536 adjusted to 131072
090821 21:08:56 [Warning] No argument was provided to --log-bin, and --log-bin-index was not used; so replication may break when this MySQL server acts as a master and
/usr/syno/mysql/libexec/mysqld: Table 'mysql.plugin' doesn't exist
090821 21:08:56 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
InnoDB: No valid checkpoint found.
j'ai donc créé un fichier my.cnf où j'ai mis en commentaire la ligne
depuis mysql fonctionne mais je n'ai plus acces aux storage table de type "innodb". j'utilise myisam
Voici le contenu de mon fichier Diskstation.err
090913 15:20:35 mysqld_safe Starting mysqld daemon with databases from /volume1/@database/mysql
090913 15:20:35 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
090913 15:20:35 InnoDB: Operating system error number 13 in a file operation.
InnoDB: The error means mysqld does not have the access rights to
InnoDB: the directory.
InnoDB: File name ./ibdata1
InnoDB: File operation call: 'open'.
InnoDB: Cannot continue operation.
090913 15:20:36 mysqld_safe mysqld from pid file /tmp/mysqld.pid ended
Je suis en root je ne vois pas pourquoi j'aurais un problème de droits ???
Attention les droits doivent (ou devraient : a vérifier sur ton nas) être les suivants :
répertoire : /volume1/@database/mysql/mysql
Tous les fichiers propriétés de admin:users
voir copie écran :
-rw-rw---- 1 admin users 4096 Sep 12 16:45 columns_priv.MYI
-rw-rw---- 1 admin users 0 Sep 12 16:45 columns_priv.MYD
-rw-rw---- 1 admin users 10466 Sep 12 16:45 user.frm
-rw-rw---- 1 admin users 8955 Sep 12 16:45 tables_priv.frm
-rw-rw---- 1 admin users 4096 Sep 12 16:45 tables_priv.MYI
-rw-rw---- 1 admin users 0 Sep 12 16:45 tables_priv.MYD
-rw-rw---- 1 admin users 8875 Sep 12 16:45 procs_priv.frm
-rw-rw---- 1 admin users 4096 Sep 12 16:45 procs_priv.MYI
-rw-rw---- 1 admin users 0 Sep 12 16:45 procs_priv.MYD
-rw-rw---- 1 admin users 9996 Sep 12 16:45 proc.frm
-rw-rw---- 1 admin users 2048 Sep 12 16:45 proc.MYI
-rw-rw---- 1 admin users 0 Sep 12 16:45 proc.MYD
-rw-rw---- 1 admin users 9510 Sep 12 16:45 host.frm
-rw-rw---- 1 admin users 2048 Sep 12 16:45 host.MYI
-rw-rw---- 1 admin users 0 Sep 12 16:45 host.MYD
-rw-rw---- 1 admin users 9582 Sep 12 16:45 db.frm
-rw-rw---- 1 admin users 5120 Sep 12 16:45 db.MYI
-rw-rw---- 1 admin users 5280 Sep 12 16:45 db.MYD
drwx------ 2 admin users 4096 Sep 12 16:45 .
-rw-rw---- 1 admin users 728 Sep 12 16:45 user.MYD
Par exemple chez moi ibdata1 est bien propriétaire de admin:users !
drwxr-xr-x 4 admin root 4096 Aug 21 16:27 ..
drwx------ 2 root root 4096 Aug 21 19:26 test
-rw-rw---- 1 admin users 10485760 Aug 21 19:36 ibdata1
-rw-rw---- 1 admin users 5242880 Aug 21 19:36 ib_logfile0
-rw-rw---- 1 admin users 5 Aug 21 21:18 DiskStation.pid
-rw-rw---- 1 admin users 625 Aug 21 21:18 DiskStation-bin.index
-rw-rw---- 1 admin users 30446 Aug 21 21:20 DiskStation-bin.000025
-rw-rw---- 1 admin users 19583 Aug 21 21:21 mysqld-bin.000001
-rw-rw---- 1 admin users 344 Aug 21 21:22 mysqld-bin.000002
-rw-rw---- 1 admin users 25805 Aug 21 21:24 mysqld-bin.000003
-rw-rw---- 1 admin users 16605 Aug 21 21:25 mysqld-bin.000004
Bien vérifier que c'est le cas ...
Pour avoir ce type d'affichage il faut (en mode telnet ou ssh) effectuer la commande suivante.
ls -ltra
Les droits sont ok j'ai meme tout mis en 777 pour etre sur.
DiskStation> ls -lrt /volume1/@database/mysql/
-rwxrwxrwx 1 admin users 7 Jul 1 2008 VERSION
-rwxrwxrwx 1 admin users 5242880 Jul 1 2008 ib_logfile1
drwxrwxrwx 2 admin users 12288 Sep 10 19:09 mysql
drwxrwxrwx 2 admin users 4096 Sep 11 19:38 wordpress
-rwxrwxrwx 1 admin users 10485760 Sep 11 22:26 ibdata1
-rwxrwxrwx 1 admin users 5242880 Sep 13 21:56 ib_logfile0
-rwxrwxrwx 1 admin users 55531 Sep 13 21:56 DiskStation.err
Par contre dans le repertoire mysql je n'ai aucun fichier.
Je vois plusieurs choses :
la version de Mysql pour le DSM 2.2 942 est la suivante. MYSQL_VERSION="5.1.34"
tu peux vérifier cela dans le fichier /usr/syno/etc.defaults/rc.d/S21Mysql.sh (début du fichier)
que vaut la version de ton fichier VERSION qui est dans /volume1/@database/mysql ? (normalement la même chose).
le fait que ton répertoire mysql soit vide n'est pas trop bon. normalement il y a des fichiers de type .frm ....
De plus je vois que les dates des fichiers suivants ne sont pas les bonnes.
chez moi ils ont presque les mêmes valeurs de temps. (ce qui est normal car les fichiers ib_logfile1 et 0 correspondent aux transactions faites sur ibdata1.
-rw-rw---- 1 admin users 5242880 Sep 13 18:39 ib_logfile1
drwx------ 4 admin users 4096 Sep 13 18:41 .
-rw-rw---- 1 admin users 131958 Sep 13 18:41 DiskStation.err
-rw-rw---- 1 admin users 10485760 Sep 13 18:42 ibdata1
-rw-rw---- 1 admin users 5242880 Sep 13 18:42 ib_logfile0
Je pense que ta mise à jour de mysql c'est planté.
1) modifier la valeur du fichier VERSION (celui qui est dans /volume1/@database/mysql pour y placer une valeur différente de celle attendue (donc de la 5.1.34.
Normalement en démarrant mysql le serveur devrait lancer la procédure de mise à jour.
extrait du /usr/syno/etc.defaults/rc.d/s21mysql.sh (mode Start)
DataDir=${VolHome}/@database
NeedUpgrade=1 ====> il positionne un flag pour mettre à jour mysql
if [ ! -d ${DataDir}/mysql ]; then ===> il cherche le rep mysql que tu as donc il ne devrait pas lancer le contenu du if.
echo "Initialize MySQL..."
mkdir $DataDir
chown admin $DataDir
su -l admin -c "/usr/syno/mysql/bin/mysql_install_db --datadir=${DataDir}/mysql --force"
echo $MYSQL_VERSION > ${DataDir}/mysql/VERSION
elif [ -f ${DataDir}/mysql/VERSION ]; then ===> c'est là que l'on va essayer de le tromper. le pgm regarde les versions et nous allons les forcer à des valeurs différentes.
grep $MYSQL_VERSION ${DataDir}/mysql/VERSION > /dev/null 2>&1
if [ $? -eq 0 ]; then
NeedUpgrade=0
fi
fi
if [ $NeedUpgrade -eq 1 ]; then ===> ICI !
echo "Need to upgrade MySQL database. Starting..."
UpgradeDatabase
fi
fi
echo "Starting MySQL..."
${MYSQL_DIR}/share/mysql/mysql.server start --datadir=${DataDir}/mysql --pid-file=${PID_FILE} ${MYSQL_ARGS}
echo "MYSQL data dir = ${DataDir}/mysql..."
2) après cela essaye de voir ce que contiens le fichier Diskstation.err mais je pense que tant que tu auras le fichier ibdata et les ib_logfilexx non synchro mysql ne fonctionnera pas avec les storeengine innodb.
voir plus tard.
En fait les deux versions ne sont pas les mêmes. La version du fichier VERSION dans @database est la 5.0.51, et celle dans le S21mysql.sh est 5.1.34.
Je crois que comme tu l'as dit la mise à jour à du déconner et qu'il me reste plus que ce que je redouté à faire... c'est à dire tout formater et repartir sur une base "propre" :(
avant tu peux tester cette opération. (fais des sauvegardes avant)
- depuis l'interface d'admin tu désactive "Mysql"
une fois cette opération faite :
- tu vas dans /volume1/@database/mysql
- tu renomme /volume1/@database/mysql/mysql en /volume1/@database/mysql/mysql.origine
(utilisation du mv (move unix))
- tu retourne dans l'interface d'admin du syno
- tu coches "activer mysql" et tu valide (cela risque de durer qqs temps)
puis tu tente de te connecter à mysql ou tu regarde le contenu du fichier Diskstation.err pour voir ce qu'écrit le serveur mysql
Merci de ton aide mais j'ai maintenant tout formatter.
